Knowledge Base Article
Why are the nPERST and OSC_CLK_1 pins not listed under Transceiver pins in the Intel® Stratix® 10 GX, MX, TX, and SX Device Family Pin Connection Guidelines?
Description
Due to a problem in the documentation, the Intel® Stratix® 10 GX, MX, TX, and SX Device Family Pin Connection Guidelines do not include the nPERST[L, R][0:2] pins and OSC_CLK_1 pin under the Transceiver section.
Resolution
If you are using transceivers in your design, make sure you are meeting the guidelines for these pins as listed in the connection guidelines under the section Dedicated Configuration/JTAG Pins (OSC_CLK_1) and Optional/Dual-Purpose Configuration Pins (nPERST[L,R][0:2]). This problem is fixed starting with version 2018.08.16 of the Intel® Stratix® 10 GX, MX, TX, and SX Device Family Pin Connection Guidelines.
Updated 19 days ago
