Knowledge Base Article
Why are the M and N counter parameters for my PLL being seen as invalid during synthesis?
Description
The Quartus® II Software views parameters and generics as global.  If user created parameters or generics are have the same names as parameters used in Altera IP, then settings can be inadvertently overridden.
Altera PLL Example:
If user created parameters called “M” or ”N” are created at the top level of a design containing Altera PLLs at a lower level in the hierarchy, this can affect the instantiated PLLs and result in errors and unexpected behaviour:
Example Error Message:
Error: <Design Hierarchy Path>:auto_generated|pll1" has port CLK[0] connected but parameters clk0_counter is either unspecified or set to Unused
Resolution
To work around this problem ensure a user defined prefix is added to user parameters to avoid namespace conflicts.
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 2 months ago
Version 2.0
