Knowledge Base Article
Why are the following errors seen when I try to simulate the PCIe Avalon-MM Root Port configuration?
Description
Due to a bug in Quartus® II software versions v12.1SP1 and earlier, the auto-generated ModelSim® setup script, msim_setup.tcl, produces errors of the format shown below when using Stratix® V or Arria® V GZ Hard IP Core for PCI Express® IP configured as an Avalon® Memory-Mapped (Avalon-MM) Root Port.  These errors are observed in ModelSim when using the setup script located in the following directory:
<Qsys name>\simulation\mentor\msim_setup.tcl
# ** Error: (vopt-7) Failed to open info file "pcie_sv_hip_avmm_0/_info" in read mode.
# No such file or directory. (errno = ENOENT)
# ** Error: ./..//submodules/altpcie_sv_hip_avmm_hwtcl.v(2354): Module 'altpcietb_bfm_log_common' is not defined.
# ** Error: ./..//submodules/altpcie_sv_hip_avmm_hwtcl.v(2355): Module 'altpcietb_bfm_req_intf_common' is not defined.
# ** Error: ./..//submodules/altpcie_sv_hip_avmm_hwtcl.v(2356): Module 'altpcietb_bfm_shmem_common' is not defined.
# ** Error: ./..//submodules/altpcie_sv_hip_avmm_hwtcl.v(2357): Module 'altpcietb_ltssm_mon' is not defined.
# Optimization failed
# Error loading design
Resolution
The issue is only observed with the standalone IP simulation scripts.  The Auto-Generated full testbench works correctly.
As a workaround remove the four lines 2354 to 2357 shown below found in the file altpcie_sv_hip_avmm_hwtcl.v
      altpcietb_bfm_log_common bfm_log_common ( .dummy_out (bfm_log_common_dummy_out));
      altpcietb_bfm_req_intf_common bfm_req_intf_common ( .dummy_out (bfm_req_intf_common_dummy_out));
      altpcietb_bfm_shmem_common bfm_shmem_common ( .dummy_out (bfm_shmem_common_dummy_out));
      altpcietb_ltssm_mon ltssm_mon ( .dummy_out (ltssm_dummy_out), .ep_ltssm (5\'h0), .rp_clk (sim_pipe_pclk_out), .rp_ltssm (ltssmstate), .rstn (npor));
This issue will be fixed in a future release of the Quartus® II software.
Updated 2 months ago
Version 2.0
