Knowledge Base Article
Why are the E-Tile Transceiver Native PHY IP rx_parallel_data bits missing in the PAM4 mode?
Description
You may observe missing E-Tile Transceiver Native PHY IP rx_parallel_data bits in the PAM4 mode if you don’t run the initial adaptation during the PMA bring up flow.
Resolution
To work around this problem, run the initial adaptation before operating E-Tile receiver channels. For more information, refer to the PMA Bring up Flow section in the E-Tile Transceiver PHY User Guide.
Updated 2 months ago
Version 3.0
