Knowledge Base Article
Why are the Datasheet Report and Setup / Hold Time Reports not generated automatically?
Description
The Intel® Quartus® Prime software version 15.1 and later, does not automatically generate the Datasheet report and the Setup / Hold Time reports after a compile. The generation process of those reports was removed from the Intel Quartus default flow to improve the compile time.
Resolution
To generate these reports as part of Intel® Quartus® Prime compile flow, follow the next steps:
  1. Create a new tcl file and name it 'report_datasheet.tcl'
  2. Add the following lines to report_datasheet.tcl
    create_timing_netlist
    read_sdc
    update_timing_netlist
    # Generate Datasheet Report
    report_datasheet -file datasheet_report.rpt -multi_corner
    # Generate IO Report
    qsta_utility::generate_all_io_timing_reports -file io_report.rpt
  3. In Assignments > Settings > 'Timing Analyzer', add report_datasheet.tcl in the 'TCL Script File name' field.
  4. Make sure that 'Run default timing analysis before running custom script' is checked.
After this change, both reports will be generated as part of the compile flow.
Updated 3 months ago
Version 2.0
