Knowledge Base Article
Why are the clock constraints for ALTPLL incorrect when using derive_pll_clocks?
Description
Due to a problem in the Quartus® Prime software version 16.0 and 16.0 Update 1, you may see that the phase value is incorrect in the constraints generated by derive_pll_clocks. This occurs when using the ALTPLL IP.Resolution
This problem is fixed beginning with the Quartus Prime software version 16.0 Update 2.Updated 1 month ago
