Knowledge Base Article
Why are my "rx_invpolarity" and "tx_invpolarity" bits unconnected at the top-level of my Hard XAUI Phy in my Arria II GX or Stratix IV GX design?
Description
Rx_invpolarity and Tx_invpolarity bits unconnected at top-level of Hard XAUI Phy in Arria® II GX and Stratix® IV GX due to a parameter mismatch within the Megawizard-generated files.
Resolution
Currently, there is a parameter mismatch in the Mega-wizard generated hxaui.v file. This is scheduled to be fixed in an upcoming release of Quartus®.
As a workaround, simply edit the hxaui.v file.  "Use_control_and_status_ports" should be defaulted to 1, while "external_pma_ctrl_reconf" should be defaulted to 0.
Furthermore, edit this line:
if (use_control_and_status_ports == "true" & external_pma_ctrl_reconf == "false" ) begin: use_cs_ports_true
To read:
if (use_control_and_status_ports == 1 & external_pma_ctrl_reconf == 0 ) begin: use_cs_ports_true
Updated 2 months ago
Version 2.0
