Knowledge Base Article
Why are illegally generated clocks reported in the timing report when using the F-Tile PMA and FEC Direct PHY FPGA IP on Agilex™ 7 devices in Quartus® Prime Pro Edition Software v23.4?
Description
Due to a problem in the Quartus® Prime Pro Edition Software v23.4, illegally generated clocks are reported in the timing report when using the F-Tile PMA and FEC Direct PHY FPGA IP on Agilex™ 7 devices in the Quartus® Prime Pro Edition Software v23.4. The following screenshot is an example showing illegally generated clocks in the timing report.
This problem is due to the F-Tile PMA and FEC Direct PHY FPGA IP generating timing constraints for tx_clkout2 and rx_clkout2 ports that have not been enabled in the IP.
Resolution
To work around this problem, enable the tx_clkout2 and rx_clkout2 ports in the F-Tile PMA and FEC Direct PHY FPGA IP even if not used. Alternatively, ignore those illegally generated clocks in the timing report.
This problem has been fixed in the Quartus® Prime Pro Edition Software v24.1.
Updated 2 months ago
Version 2.0
