Knowledge Base Article
Why are bidirectional mem_dbi_n ports created when the 'Enable DM Pins' option is selected in the Arria 10 DDR4 controller?
Description
You may see bidirectional mem_dbi_n ports exposed when you create an Arria® 10 DDR4 controller with the 'Enable DM pins' options selected inside the IP Catalog GUI.
In DDR4, the data mask (DM) and data bus inversion (DBI) features share the same pins, but cannot be enabled at the same time. When the DM or DBI feature is selected, the bidirectional mem_dbi_n ports will be exposed.
Resolution
Updated 17 days ago
Version 2.0
