Knowledge Base Article
Why am I unable to program the EPCQ-L configuration device with a .jic file on an Intel® Arria® 10 SoC Development Kit?
Description
You might see the following error message in the Intel® Quartus® Prime Software Programmer when programming the EPCQ-L configuration device with a .jic file on a Revision B Intel® Arria® 10 SoC Development Kit.
Error (209012) : Operation Failed. CONF_DONE failed to go high
By default, the JTAG chain on the development kit consists of an Intel Arria 10 FPGA, its HPS and a MAX® V device (the I/O MUX CPLD). In addition to this, the TCK frequency of the on-board Intel® FPGA Download Cable II defaults to 24 MHz
Since the minimum JTAG TCK period for MAX V devices is 100 ns, it is the slower device in the JTAG chain and contributes towards the configuration failure.
Resolution
To program the EPCQ-L device on the Intel Arria 10 SoC Development Kit successfully with a .jic file, follow either of these two steps:
  • While programming with the default board settings, (Intel Arria 10 and MAX V devices enabled in the JTAG chain) reduce the JTAG clock to 6 MHz with the command : "jtagconfig --setparam <cable name> JtagClock 6M"
  • Remove the MAX V CPLD from the chain by setting the 3rd bit of DIP SW3 to the OFF position.
Updated 3 months ago
Version 2.0
