Knowledge Base Article
Why am I unable to connect signals to Altera components in Qsys?
Description
You may see this behavior when the environment variable is set in your enviroment and SOPC Builder has been launched before you launch Qsys.
Resolution
To correct this behavior, follow the steps below:
- Unset the enviroment variable .
- Delete the directory .altera.quartus/ip in your user directory.
- For Linux systems, ~/.
- For Windows, C:\Documents and Settings\<user name> or C:\Users\<user name>
The variable is deprecated for the Quartus II software version 9.0 or later.
Updated 2 months ago
Version 3.0No CommentsBe the first to comment
