Knowledge Base Article
Why am I seeing readback data corruption on my Avalon memory-mapped reconfiguration interface of the F-tile Ethernet Multirate Intel® FPGA IP?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 23.1, readback data corruption on the Avalon memory-mapped reconfiguration interface of the F-tile Ethernet Multirate Intel® FPGA IP will occur if the Avalon memory-mapped interface read transaction is in progress when both the i_p<n>_rst_n  and i_reconfig_reset are asserted simultaneously. In this event, the first data being read back from the underlying port of the Ethernet hard IP will be invalid.
Resolution
To work around this problem, if i_p<n>_rst_n and i_reconfig_reset are asserted simultaneously during an Avalon memory-mapped interface read transaction to the underlying port of the Ethernet hard IP. You should ignore the readback data of the first read transaction and perform an additional read to the same location to obtain the proper readback data value.
Updated 2 months ago
Version 2.0
