Knowledge Base Article
Why am I seeing Design Assistant(DA) warnings with high/medium severity for GTS Dynamic Reconfiguration Controller IP designs?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.1, you may see DA warnings with high/medium severity for GTS Dynamic Reconfiguration Controller IP designs.
Resolution
There is no workaround for this problem in the Quartus® Prime Pro Edition software version 25.1; however, as these warnings are harmless, they can be ignored.
This problem is fixed beginning with the Quartus® Prime Pro Edition software version 25.1.1.
Updated 3 months ago
Version 2.0
