Knowledge Base Article
Why am I not able to see Pre-emption settings in BSP Drivers when using IIC?
Description
Auto Pre-emption does not support Internal Interrupt Controller of NIOS II® processor. There was a problem with the documentation.
Resolution
To be able to use Pre-emption feature, Vectored Interrupt Controller would be the only solution to do so, since IIC does not support pre-emption features.
The documents will be updated to clarify the IIC support issue of pre-emption.
Updated 2 months ago
Version 2.0
