Knowledge Base Article
Why am I getting “Found 1 instances of uninferred RAM logic” message due to /*synthesis preserve*/ in an unrelated port?
Description
For an example in the code below, Quartus® Standard will have issues with RAM inference because of /*synthesis preserve*/
module mem
#(parameter DATA_WIDTH=8, parameter ADDR_WIDTH=6) (
                input [(DATA_WIDTH-1):0] data,
                input [(ADDR_WIDTH-1):0] read_addr, write_addr,
                input we, clk,
                output  [(DATA_WIDTH-1):0] q,
                output  reg     [3:0]   state = 0/*synthesis preserve*/
simple_dual_port_ram_single_clock simple_dual_port_ram_single_clock_inst (
.data (data),
.read_addr (read_addr),
.write_addr (write_addr),
.we (we),
.clk (clk),
.q (q)
Resolution
The issue is caused by a known limitation where any preserve in a module declaration is applied to the whole module when using Verilog 95 style. To fix this, use Verilog 2001 attribute style. Namely:
replace:
with:
(* preserve *) output  reg     [3:0]   state = 0
This issue is not present in the Quartus® Pro version of the software. For Quartus® Standard versions, please use the workaround.
Updated 3 months ago
Version 2.0
