Knowledge Base Article
Which Triple Speed Ethernet (TSE) MAC registers must be set to run a simulation?
Description
To configure the Altera® Triple Speed Ethernet (TSE) MegaCore® function for simulation, you need to set the MAC and PCS registers according to the table below.
Please take note that command_config register should be the last register written because TSE operation will start when TX_EN and RX _EN in the command_config register are set. The order that the other registers are configured is not critical.
Registers in bold are basically required configurations for TSE MAC and PCS respectively to start its operation.
Table 1: MAC registers
Register OffsetRegister NameValueNotes
0x08command_config0x400003Btransmit and receive paths enabled, gigabit ethernet enabled, promiscuous mode enabled, RX frame padding removal enabled, RX erroneous frame discard enabled
0x04scratch0xAAAAAAAAN/A
0x0Cmac_00x17231C00
MAC address of 0x001C23174ACB
0x10mac_10x0000CB4A
0x14
frame_length
0x533
Maximum frame length of 1518 bytes
0x18
pause_quant
0x0f
N/A
0x1C
RX_section_empty
0x10
N/A
0x20
RX_section_full
0x10
N/A
0x24
TX_section_empty
0x10N/A
0x28
TX_section_full
0x10
N/A
0x2C
RX_almost_empty
0x08
N/A
0x30
RX_almost_full
0x08
N/A
0x34
TX_almost_empty
0x08
N/A
0x38
TX_almost_full
0x0A
N/A
Table 2: PCS registers
0x00
PCS control
0x00000000
No features enabled
0x20scratch0x0000AAAAN/A
0x28if_mode0x00000009
Enable SGMII, SGMII speed - gigabit
Updated 3 months ago
Version 3.0
