Knowledge Base Article
Which HPS SDRAM Controller command ports are associated with which AXI interfaces?
Description
The Cyclone® V and Arria® V HPS SDRAM controller allows up to 3 AXI™ interfaces.  The following shows the mapping of the SDRAM controller command port to the AXI interface read/write channel.
• Command port 0: f2h_sdram0 AXI Read commands
• Command port 1: f2h_sdram0 AXI Write commands
• Command port 2: f2h_sdram1 AXI Read commands
• Command port 3: f2h_sdram1 AXI Write commands
• Command port 4: f2h_sdram2 AXI Read commands
• Command port 5: f2h_sdram2 AXI Write commands
Resolution
This information is included starting with release 15.1 of the Arria® V and Cyclone® V Handbook.
Updated 20 days ago
Version 2.0
