Knowledge Base Article
Where can I download the design example mentioned in AN 367: Implementing PLL Reconfiguration in Stratix® II devices?
Description
The design example link mentioned in the AN 367: Implementing PLL Reconfiguration in Stratix® II Devices documentation is currently unavailable. However, you can find or download the design example from the links in the Resolution section.
Resolution
Download design examples from the following links:
- Altera-Stratix+Series-Stratix+II-Design+Elements-Applications+Library-Altera.Application_Library_10.zip
- Altera-Stratix+Series-Stratix+II-Design+Elements-Applications+Library-Altera.Application_Library_11.zip
- Altera-Stratix+Series-Stratix+II-Design+Elements-Applications+Library-Altera.Application_Library_12.zip
Updated 1 month ago
