Knowledge Base Article
When using the Stratix V Hard IP for PCI Express, why is the No Command Completed Support (bit 18) of the Slot Capability Register incorrectly set?
Description
Due to a problem in the Stratix® V Hard IP for PCI® Express, this bit is incorrectly set.
Resolution
To work around this problem:
1. Go to:
<your Altera install directory>\<your Quartus® II version>\ip\altera\altera_pcie\altera_pcie_sv_hip_avst\pcie_sv_parameters_common.tcl
2. Replace:
add_parameter          advanced_default_hwtcl_no_command_completed string "true"
with
add_parameter          advanced_default_hwtcl_no_command_completed string "false"
3. Remove:
set_parameter_value no_command_completed_hwtcl "true"
4. Go to:
<your Altera install directory>\<your Quartus® II version>\ip\altera\altera_pcie\altera_pcie_sv_hip_avst\pcie_sv_parameters.tcl
5. Modify the line
if { == 1 } {
to:
if { == 1 } {
         set advanced_default_parameter_override  [ get_parameter_value advanced_default_parameter_override ]
                   if { == 0 } {
                   } else {
                      set_parameter_value no_command_completed_hwtcl  [ get_parameter_value  advanced_default_hwtcl_no_command_completed                          ]
6. Regenerate the IP core, recompile your design, and simulate.
This problem is scheduled to be fixed in a future version of Quartus® II software.
Updated 3 months ago
Version 2.0
