Knowledge Base Article
When using PCI Express, can 32-bit addressing be used to access a 64-bit BAR?
Description
In the case of a 64-bit BAR that is up to 4 GB in size and located from offset 0 of the BAR, 32-bit addressing may be used where applicable.
If the addressable range is greater than 4 GB in size, this will by definition span outside of 32-bit address space. 32-bit addressing will be unable to access this BAR.
Updated 2 months ago
