Knowledge Base Article
When using encryption and/or decompression in Active Serial (AS) mode, is configuration time affected?
Description
No, when using the AS configuration scheme with encryption and/or decompression used, there will be no impact on the configuration time required when compared with unencrypted or uncompressed configuration schemes.
Resolution
Only when using Fast Passive Parallel (FPP) with encryption and/or decompression requires a DCLK that is × or × the data rate.
Updated 27 days ago
