Knowledge Base Article
When performing Link Disable-Enable loop testing with the R-Tile Avalon® Streaming FPGA IP for PCI Express*, why does the host system report Polling.Active timeout failures?
Description
Due to a problem in the R-Tile Avalon® Streaming FPGA IP for PCI Express*, Host systems may report Polling.Active timeout failures when running LTSSM Link disable-enable loop tests. This failure is limited to Port 0 of the R-Tile Avalon® Streaming FPGA IP for PCI Express*.
Resolution
This problem has no functional implication, and is not planned to be fixed in a future version of the Quartus® Prime Pro Edition Software.
Updated 3 months ago
