Knowledge Base Article
When I create a hexadecimal (Intel-Format) output file (.hexout) for SRAM in the Convert Programming Files window (Tools menu), what radix should the start address of my .hexout file be entered as?
Description
When generating the .hexout file through the Convert programming files window, you can specify the start address in the Options window. You must enter the start address as a decimal value.
When generating the .hexout file through the Compiler settings --> Chips & Devices --> Device & Pin options --> Programming Files window, the start address must be entered as a hexadecimal value.
Updated 3 months ago
Version 2.0
