Knowledge Base Article
When compiling an Intel® Cyclone® 10 FPGA design, why do I see the following Internal Error: Sub-system: FDI_DATA, File: /quartus/ddb/fdi/fdi_timing_model.cpp, Line: 753
Description
Due to a problem with the Intel® Quartus® Prime Pro Edition Software v18.0, Intel® Cyclone® 10 GX FPGA designs might see the following Internal Error: Sub-system: FDI_DATA, File: /quartus/ddb/fdi/fdi_timing_model.cpp, Line: 753 during the fitter stage of compilation.
This problem occurs when the Intel Cyclone 10 GX device family is installed without installing the Intel® Arria® 10 device family files.
Resolution
You are advised to install the Intel® FPGA Arria® 10 device family database file to work around this problem.
This problem is fixed starting with Intel® Quartus® Prime Pro Edition Software version 19.1.
Updated 3 months ago
Version 2.0
