Knowledge Base Article
When compiling a design in DSE II, the compilation fails if the .qsf does not list all of your design files
Description
When Design Space Explorer (DSE) II compiles a design, it first creates an archive of the design. The Quartus II software archive flow automatically discovers all of your project files, even if they are not listed in the Quartus II Settings File (.qsf). However, the archiving function in DSE II does not automatically discover the files; the archiving step will fail, causing the entire compilation to fail, if the project files are not specifically listed in the .qsf.
Resolution
This issue is fixed in the Quartus II software version 15.0.
For previous software releases, there are two ways to resolve this problem:.
- Add the missing files to the .qsf and then recompile the design.
- Archive your design in the Quartus II software, then in DSE II navigate to
Archive Settings>Use existing design archiveand specify the archive file in theQuartus II archive (.qar) file namedialog box. Then run the compilation or design exploration.
Updated 2 months ago
Version 3.0No CommentsBe the first to comment
