Knowledge Base Article
What's the minimum DQ width when External Memory Interface Hard PHY Only mode is used in Intel Agilex® device?
Description
Due to a limitation in the Intel Agilex® device, the minimum DQ width is 16 bits in External Memory Interface Hard PHY Only mode. In comparison, the minimum DQ width is 8 bits in External Memory Interface Hard PHY and Hard Controller mode.
Resolution
The 8 bits DQ width is not planned to be supported in External Memory Interface Hard PHY Only mode in Intel Agilex® device.
Updated 1 month ago
Version 2.0
