Knowledge Base Article
What timing constraints are used by the Design Assistant?
Description
The Quartus® II Design Assistant (DA) does not use any constraints from the Synopsys Design Constraints (.sdc) file. During processing you may see the following messages:
Info (332164): Evaluating HDL-embedded SDC commands Info (332104): Reading SDC File: '<file name>.sdc'
These messages occur because the DA uses the timing netlist during processing.
Resolution
Updated 2 months ago
