Knowledge Base Article
What should I do if I receive a MAX PLUS® II internal error?
Description
An internal error in the MAX PLUS II software indicates that the software diagnostics have discovered an error. Usually this internal error indicates a problem in the software or insufficient memory.If you receive a MAX PLUS II internal error, file a service request on www.altera.com/Mysupport
The MAX PLUS II version that you are using (and whether you have tried to use the latest version).
- The exact error message and when the error occurred (e.g., in the Database Builder during compilation).
- The frequency of the error (e.g., every time you perform a certain action, randomly, every third compilation).
- Your system information, including the following:
- Brand of computer
- Operating system and version
- Memory
- Free disk space
- The design files that generate the error (e.g., the <design file>.acf and <design file>.gdf).
- Which device you are using.
- Any additional information about the problem.
Updated 3 months ago
