Knowledge Base Article
What should be considered to reduce Simultaneous Switching Noise (SSN) on a PCI interface implemented on my Cyclone series FPGA?
Description
There are SSN considerations to make when the Address/Data (AD) bus on a target PCI interface  changes from output to high impedance (Hi-Z), on a Cyclone® series device.
For example, if a Cyclone series device acting as the target PCI device drives the AD bus from high to low (or low to high) and a short time after that (several nanoseconds), the output enable (OE) signal goes from high (output) to low( Hi-Z) the FPGA will appear to output a short pulse before disabling the output driver.
In this case, signals on the AD bus may ring with large amplitude because the AD bus has gone into a high impedance state immediately after a pulse injection.
If multiple AD signals near the clock input pin are ringing, this may cross-talk to the clock input pin and the target FPGA may capture the wrong clock edge.
Resolution
Here are two possible workarounds to avoid this.
1. Toggle the OE signal earlier so that OE goes low before the AD bus toggles.
2. Prevent the AD bus from toggling when OE goes from high to low.
Updated 1 month ago
Version 2.0
