Knowledge Base Article
What output clock should I connect to the Native PHY Intel FPGA IP when using a fPLL as a transceiver TX PLL on Stratix® V, Arria® V, and Cyclone® V transceiver devices?
Description
The output clock used to connect to the Native PHY Intel® FPGA IP when using a fPLL as a transceiver TX PLL on Stratix® V, Arria® V, and Cyclone® V transceiver devices will vary depending on whether dynamic reconfiguration of the fPLL is enabled or not.
Resolution
When dynamic reconfiguration of the fPLL is not enabled, you must connect the fPLL 'outclk_0' port to the Native PHY 'ext_pll_clk' port.
When dynamic reconfiguration of the fPLL is enabled, you must connect to fPLL 'phout[0]' port to the Native PHY 'ext_pll_clk' port. The 'phout' port is enabled by selecting the "Enable access to PLL DPA output port" option of the PLL parameter editor "Settings" tab.
Updated 2 months ago
