Knowledge Base Article
What is the write non-volatile configuration register (NVCR) cycle time specificatiion, for the quad-serial configuration devices (EPCQ)?
Description
When you write to the NVCR, the device initiates a self-timed write NVCR cycle immediately after the nCS signal is driven high.  The self-timed write NVCR cycle time specifications is as follows:
Typical : 0.2 s,  Maximum : 3 s
You can check the write in progress bit in the status register by executing the read status operation while the self-timed write NVCR cycle is in progress.
Related Articles
Updated 2 months ago
Version 3.0
