Knowledge Base Article
What is the size of the .core.rbf file for FPGA core fabric configuration from hardware processor system (HPS)?
Description
The maximum size of the .core.rbf file for FPGA core fabric configuration from hard processor system (HPS) is the same as the configuration bit stream size for FPGA configuration from a configuration device.
Resolution
You can find the configuration bit stream size for your target device in the Configuration Bit Stream Sizes section of the respective device datasheet.
Updated 2 months ago
Version 2.0
