Knowledge Base Article
What is the Power supply connection for Pins HPS_Shared_Q2_2 and HPS_Shared_Q4_2 of Arria 10 SoC ?
Description
In the Intel® Arria® 10 GX, GT, and SX Device Family Pin Connection Guidelines document, the connection guideline of Pins HPS_Shared_Q2_2 and HPS_Shared_Q4_2 is as below:
"If used as the NAND Ready/Busy input, connect this pin through a 1-10-kΩ pull-up resistor to VCCIO_HPS in the dedicated I/O bank which the NAND_RB pin resides. If unused, program it in the Intel Quartus Prime software as an input with a weak pull-up".
This is incorrect, the correct statement should be:
"If used as the NAND Ready/Busy input, connect this pin through a 1-10-kΩ pull-up resistor to VCCIO_2L in the dedicated I/O bank which the NAND_RB pin resides. If unused, program it in the Intel Quartus Prime software as an input with a weak pull-up".
Resolution
This typo is scheduled to be fixed in future Quartus Prime release.
Updated 4 months ago
Version 2.0
