Knowledge Base Article
What is the most recent version of SVF2JAM?
Description
SVF2JAM is a conversion program that converts existing Serial Vector Files (.svf) into JamTM Standard Test and Programming Language (STAPL) Files (.jam). SVF2JAM performs a linear conversion of SVF commands to Jam STAPL commands. It does not add any additional algorithmic or file-reducing functionality. It is provided as a proof-of-concept support method, particularly when programming or configuring devices that do not support Jam STAPL directly. This is not an optimal solution from a file size or programming/configuration times point of view.You can run SVF2JAM on a 32-bit PC Windows operating system. Go to the Jam STAPL Web Site to download the program or to see the latest supported version.
Updated 3 months ago
