Knowledge Base Article
What is the minimum transceiver reference clock frequency for an Arria 10 device fPLL?
Description
The minimum refclk frequency for an Arria® 10 device transceiver fPLL is 50MHz.
The Quartus® Prime will not allow the use of a reference clock below 50MHz other than when used with the HDMI Design Example.
For the HDMI Design Example only, a 25MHz refclk is used. Refer to the Intel Arria® 10 HDMI IP Core Design Example User Guide to generate the HDMI Design Example.
Related Articles
The Arria® 10 Datasheet has been updated to show that a refclk frequency of 25MHz is only supported for the HDMI IP.
Updated 19 days ago
Version 2.0
