Knowledge Base Article
What is the minimum receiver data rate supported by the low-voltage differential signaling (LVDS) SERDES FPGA IP with Agilex™ 5 devices?
Description
The minimum receiver data rate supported by the low-voltage differential signaling (LVDS) SERDES FPGA IP in Agilex™ 5 devices in all modes is 600Mbps, including DPA mode, non-DPA mode and soft-CDR mode.
Resolution
To support a data rate lower than 600Mbps, you have the option to choose DDIO mode in the GPIO FPGA IP.
Updated 1 month ago
