Knowledge Base Article
What is the initial state of a state machine on power up?
Description
When synthesizing a state machine for Altera® devices, you must make sure the state machine is reset properly. All registers in an Altera device will power up in a low state, unless Not-Gate-Push-Back is used or the power-up high options are set on the register. All Altera devices support Not-Gate-Push-Back.
If the state machine is defined so that one or more of the state bits are non-zero in the reset state, then you should explicitly reset the state machine using a reset signal (see below). If the state machine is not explicitly reset in this case, the state machine could power up into an undefined state, and MAX PLUS® II will give the following message:
Info: State machine '<name>' must be reset to guarantee proper operation
To correct this problem, the state machine should be explicitly reset. Examples for AHDL, VHDL, and Verilog HDL design entry formats are shown below.
For AHDL, the reset signal should be declared and asserted.
SUBDESIGN statemachine
   clk, reset, ena, d : INPUT;
   q                  : OUTPUT;
VARIABLE
   ss: MACHINE WITH STATES (s0=1, s1=0); -- reset state is s0, state register is non-zero
BEGIN
   ss.reset = reset; -- assert this signal to properly reset the state machine
For VHDL, the initial state may be defined by an IF statement and a reset signal.
ENTITY statemachine IS
PORT(  clk  : IN STD_LOGIC;
input  : IN STD_LOGIC;
reset  : IN STD_LOGIC;
output  : OUT STD_LOGIC);
END statemachine;
ARCHITECTURE a OF statemachine IS
    TYPE STATE_TYPE IS (s1, s2); -- reset state is s1
    ATTRIBUTE ENUM_ENCODING : STRING;
    ATTRIBUTE ENUM_ENCODING OF STATE_TYPE : TYPE IS "1 0"; -- state register for s1 is non-zero
    SIGNAL state : STATE_TYPE;
BEGIN
   PROCESS (clk)
       BEGIN
          IF reset = '1' THEN state <= s2; -- causes state machine to power up in state s2
             IF (clk'EVENT AND clk = '1') THEN
                  CASE state IS
For Verilog HDL, the initial state must be defined by an IF statement and a reset signal, i.e.
module statemachine (clk, in, reset, out);
   input   clk, in, reset;
   output  out;
   reg     out;
   reg     state;
   parameter s1 = 1, s2 = 0;
   always @ (state) begin
      case (state) -- define outputs
         s1: out = 0;
   always @ (posedge clk or posedge reset) begin
      if (reset) state = s1; -- causes state machine to power up in state s1
      else case (state) -- define state transitions
            s1: if (in) state = s2;
For all HDL formats, if you do not define the state machine's initial state to be all zeros, explicitly reset the state machine, since the state machine will power up low.
See the AHDL, VHDL, and Verilog HDL sections of MAX PLUS II Help for complete information on implementing state machines in MAX PLUS II.
Updated 11 months ago
Version 3.0
