Knowledge Base Article
What is the format of Intel Hexadecimal files (.hex)?
Description
A HEX is often downloaded from a PC to a development system and run from RAM. HEXs can also be converted to binary files and programmed into a configuration device.
A sample HEX is shown below:
:10008000AF5F67F0602703E0322CFA92007780C361
:1000900089001C6B7EA7CA9200FE10D2AA00477D81
:0B00A00080FA92006F3600C3A00076CB
:00000001FF
The format for this file is:
First character (:)  =  Start of a record
Next two characters  =  Record length (in this example, 10h)
Next four characters =  Load address (in this example, 0080h)
Next two characters  =  Record type (see below)
Remaining characters =  Actual data
Last two characters  =  Checksum (i.e., sum of all bytes checksum = 00)
The last line of the file is special, and always looks like the last line shown above. HEX record types are shown below:
00 = Data record
01 = End of file record
02 = Extended segment address record
03 = Start segment address record
04 = Extended linear address record
05 = Start linear address record
Updated 1 month ago
Version 2.0
