Knowledge Base Article
What is the expected behavior of mgmt_waitrequest and the status register when using the Altera PLL Reconfig megafunction?
Description
In waitrequest mode, the mgmt_waitrequest signal will assert during PLL reconfiguration or if the PLL is in a loss of lock condition. In polling mode, the status register will be 0 (busy) during PLL reconfiguration or if the PLL is in a loss of lock condition.
In waitrequest mode, the mgmt_waitrequest signal will de-assert when PLL reconfiguration is complete.  If the PLL loses lock after reconfiguration is complete, the mgmt_waitrequest signal will become asserted again until the PLL is locked.  There may be a brief period after PLL reconfiguration is complete, but before the PLL has lost lock when mgmt_waitrequest will be de-asserted.
In polling mode, the status register will change from 0 (busy) to 1 (not busy) when PLL reconfiguration is complete.  If the PLL loses lock after reconfiguration is complete, the status register will become 0 (busy) again until the PLL is locked.  There may be a brief period after PLL reconfiguration is complete, but before the PLL has lost lock when the status register will be 1 (not busy).
Resolution
Intel recommends allowing sufficient time for the PLL to lock after PLL reconfiguration is complete prior to performing a new Avalon read or write operation.
Updated 1 month ago
Version 2.0
