Knowledge Base Article
What is the cyclic redundancy check (CRC) calculation time formula for different values of n (where n is the number of divisor)?
Description
The handbooks for Cyclone® III, Cyclone IV, Cyclone V, Arria® II, Arria V, Stratix® IV, and Stratix V devices show the maximum and minimum CRC calculation time. Refer to the Single Event Upset (SEU) Mitigation chapter of the respective device family handbook for the maximum and minimum CRC calculation time specifications.
The maximum and minimum time is calculated based on a minimum divisor and a maximum divisor settings as well as the process, voltage, and temperature (PVT) variation of the internal oscillator.
The available divisor settings are:
1. Arria II and Stratix IV devices: 1, 2, 3, 4, 5, 6, 7, 8
2. Cyclone III, Cyclone IV, Cyclone V, Arria V, and Stratix V devices: 0, 1, 2, 3, 4, 5, 6, 7, 8
If you set the divisor in between minimum and maximum, you may calculate the CRC calculation time based on the formula provided in the workaround below.
Resolution
For Arria II and Stratix IV devices:
Maximum Time (n) = 2^(n-8) * Maximum Time
Minimum Time (n) = 2^(n-1) * Minimum Time
For Cyclone III, Cyclone IV, Cyclone V, Arria V, and Stratix V devices:
Minimum Time (n) = 2^n * Minimum Time
