Knowledge Base Article
What is the correct order of DW header in PCIe err_desc_func0 bus?
Description
The correct order of DW header in err_desc_func0 is:
 err_desc_func0[127:0] = {header0, header1, header2, and header3};
Where:
* Header0 = 1st  DW => Header Byte0,   Header Byte1,   Header Byte2,   Header Byte3
* Header1 = 2nd DW => Header Byte4,   Header Byte5,   Header Byte6,   Header Byte7
* Header2 = 3rd  DW => Header Byte8,   Header Byte9,   Header Byte10, Header Byte11
* Header3 = 4th  DW => Header Byte12, Header Byte13, Header Byte14, Header Byte15
Note: Header 3 is only applicable for four DW header format.
The above rule is valid for all devices that support PCIe® core including S4GX, A2GX, and C4GX.
It is also applied for both soft IP and hard IP.
Resolution
Some updates to formatting:
Where:
* Header0 = 1st  DW => {Header Byte0,   Header Byte1,   Header Byte2,   Header Byte3}
* Header1 = 2nd  DW => {Header Byte4,   Header Byte5,   Header Byte6,   Header Byte7}
* Header2 = 3rd  DW => {Header Byte8,   Header Byte9,   Header Byte10,  Header Byte11}
* Header3 = 4th  DW => {Header Byte12,  Header Byte13,  Header Byte14,  Header Byte15}
The above rule is valid for all devices that support PCIe core including S4GX, A2GX, and C4GX.
It is also applied for both soft IP.
Updated 1 month ago
Version 2.0
