Knowledge Base Article
What is the correct flow to program a JIC file into a QSPI device when using an Intel® Stratix® 10 FPGA that has a volatile root key programmed?
Description
To program a JIC file into a QSPI device via an Intel® Stratix® 10 FPGA that has a volatile root key programmed, you need to first generate a QSPI helper image.
You then need to sign the QSPI helper image with your owner key and configure the FPGA with it before performing JIC programming.
When doing this, unselect the box associated with the default helper image in the Intel® Quartus® Prime Programmer.
Resolution
Here is an example of how to generate the QSPI helper image and sign it.
quartus_pfg --helper_image -o helper_device=1SG110HN3AS -o subtype=QSPI-o fw_source=signed_stratix10.zip qspi_helper_image.rbf
quartus_sign --family=Stratix10 --operation=sign --qky=owner.qky --pem=private.pem qspi_helper_image.rbf signed_qspi_helper_image.rbf
Refer to section 4.3 of the Intel® Stratix® 10 Device Security User Guide for further information.
