Knowledge Base Article
What is the actual frequency range specification of DCLK when using Active Serial configuration mode in Cyclone IV GX devices, when the 20MHz Internal Oscillator option is chosen?
Description
You can use the following figures for the frequency range specification of DCLK in Active Serial (AS) configuration of Cyclone® IV GX devices, when choosing 20MHz Internal Oscillator in Device and Pin Options in the Quartus® Prime software.
- Minimum 10MHz
- Typical 15MHz
- Maximum 20MHz
When choosing 40MHz Internal Oscillator, refer to the Cyclone IV Device Handbook for the frequency range.
Updated 2 months ago
