Knowledge Base Article
What files do I need to run the SignalTap® II logic analyzer in the Quartus® II software?
Description
To run the SignalTap® II logic analyzer, you need the following files:
  1. SignalTap File (.stp)
  2. SRAM Object File (.sof) with the SignalTap II analyzer enabled
Although the Quartus® II project is not required, it is recommended. The project database contains information about the integrity of the current SignalTap II session. Without the project database, there is no way to verify that the current STP file matches the SOF that is downloaded to the device. If you have an STP file that does not match the SOF you will see incorrect data captured in the SignalTap II logic analyzer.
For more information on using the SignalTap II logic analyzer, refer to the Design Debugging Using the SignalTap II Embedded Logic Analyzer chapter in volume 3 of the Quartus II Handbook.
Updated 3 months ago
Version 2.0
