Knowledge Base Article
What configuration device should be selected for the Altera Remote Update IP when using the Active Parallel configuration scheme?
Description
When the Active Parallel configuration scheme is being used, the configuration device does not need to be specified in the Altera Remote Update IP.  The default setting of EPCS128 may be used.
Updated 18 days ago
Version 2.0
