Knowledge Base Article
What are the fixed Altera™ FPGA SDM Firmware issues in Quartus® Prime Pro Edition Software version 24.1?
Description
The released Quartus® Prime Pro Edition Software version 24.1 includes Firmware fixes for the following problems (The release contains all prior fixes and supersedes earlier device firmware releases).
Fixes starting in 24.1:
- Active Serial configuration clock issues on hardware that is not designed to operate at speeds higher than 80 MHz.
- CvP peripheral image configuration time period longer than expected on Initialization Mode
- Programming File Generator tool, the settings file .pfg incorrectly saved.
- HPS boot first reconfiguration issue resulting in hanging in Agilex™ 7 M-series devices.
Please refer to the related articles at the bottom page for more details.
Resolution
Download and install Quartus® Prime Pro Edition Software version 24.1 or the Stand-Alone Quartus® Prime Pro Edition Software Programmer and Tools version 24.1 to include these fixes.
- Recompilation is not required.
- All programming files should be recreated.
- Re-run programming file generation or conversion using the Quartus® Prime Software programming file generator.
Related Articles
000097629:Why do I see SDM-based Intel® FPGAs fail to boot from QSPI flash?
000098697:Why does the Agilex™ 7 CvP Periphery Image configuration take longer than expected?
Updated 3 months ago
Version 3.0No CommentsBe the first to comment
