Knowledge Base Article
What are some benefits of having a phase-locked loop (PLL) with programmable bandwidth, such as those in Stratix™ devices?
Description
The advantage of having a PLL with programmable bandwidth is that the designer can set the bandwidth to the appropriate value to balance the need for jitter filtering and lock time.
A high bandwidth allows the PLL to track jitter, whereas a low bandwidth filters out high-frequency jitter. A high-bandwidth PLL also provides a fast lock time but allows more jitter to flow through. A low-bandwidth PLL, on the other hand, filters out more jitter, but increases lock time.
Updated 1 month ago
Version 2.0
