Knowledge Base Article
Warning(208542): Fault injection IP on device <number> does not have enough memory to store frame error.
Description
In Intel® Stratix® 10 devices and Intel Agilex® 7 devices, this warning message is displayed when injecting more than 8 errors continuously without the Read EMR using the Fault Injection Debugger.
This is because the Error Message Register (EMR) can only.
Resolution
Click Read EMR to read out error messages and clear the Error Message Register (EMR).  Then the warning will not be issued unless more than 8 errors are injected again without the Read EMR.
Updated 2 months ago
Version 2.0
