Knowledge Base Article
Warning(13469): Verilog HDL assignment warning at mbl_table_mux.sv(116): truncated value with size 24 to match size of target (23)
Description
This warning might be seen in the Quartus® Prime Pro Edition Software version 23.3 when you compile a design containing the Memory Subsystem IP that instantiates a Content-Addressable Memory IP using the MBL algorithm. It happens when a Content-Addressable Memory IP instance using MBL is connected to an external memory that is not large enough to hold both hash and key/result tables.
Resolution
This warning cannot be ignored.
To work around this problem in the Quartus® Prime Pro Edition Software version 23.3, perform one of the following solutions:
- Lower the log2 number of the key/result table
- Increase the size of your memory device
- Reduce key/result width
- Lower the number of bins per row
The problem has been fixed starting with Quartus® Prime Pro Edition software version 24.1.
Updated 4 months ago
Version 4.0No CommentsBe the first to comment
