Knowledge Base Article
Warning: Verilog HDL Always Construct warning at <file name>.v(): variable <name> is used in Always Construct, but isn't in the Always Construct's Event Control.
Description
This error occurs in the Quartus® II software version 4.0 when using thealways construct with a wildcard, e.g., always @ (*).
This problem is fixed beginning with version 4.1 of the Quartus II software.
To avoid the problem in versions earlier than 4.1, specify signals explicitly in the always construct's event control, e.g., always@(<signal 1> or <signal 2> or <signal 3>) instead of always@(*).
Updated 2 months ago
